if (cogoLine.IsStraightLine) { var dist = cogoLine.Distance; var dir = cogoLine.Direction; } else if (cogoLine.IsCircularArc) { var circArcDefinition = cogoLine.ToCircularArcDefinition(); string s = ""; //show Arc length, either entered or calculated if (circArcDefinition.IsDefinedByArcLength) { if (circArcDefinition.ArcLength.HasValue) { s += "<entered> Arc Length: " + circArcDefinition.ArcLength.Value.ToString("F3") + Environment.NewLine; } } else { if (circArcDefinition.CanCalculateArcLength()) { s += "<calc> Arc Length: " + circArcDefinition.CalculateArcLength().ToString("F3") + Environment.NewLine; } else s += "<calc> not able to calc arc length." + Environment.NewLine; } // chordLength if (circArcDefinition.IsDefinedByChordLength) { if (circArcDefinition.ChordLength.HasValue) { s += "<entered> Chord Length: " + circArcDefinition.ChordLength.Value.ToString("F3") + Environment.NewLine; } } else { if (circArcDefinition.CanCalculateChordLength()) { s += "<calc> Chord Length: " + circArcDefinition.CalculateChordLength().ToString("F3") + Environment.NewLine; } else s += "<calc> not able to calc chord length." + Environment.NewLine; } // central Angle if (circArcDefinition.IsDefinedByCentralAngle) { if (circArcDefinition.CentralAngle.HasValue) { s += "<entered> Central Angle: " + circArcDefinition.CentralAngle.Value.ToString("F3") + Environment.NewLine; } } else { if (circArcDefinition.CanCalculateCentralAngle()) { s += "<calc> Central Angle: " + circArcDefinition.CalculateCentralAngle().ToString("F3") + Environment.NewLine; } else s += "<calc> not able to calc Central Angle." + Environment.NewLine; } }
