ArcGIS.Desktop.Editing.COGO Namespace / COGOLineBuilder Class / CreateCOGOStraightLine Method
direction value in North Azimuth decimal degrees.
distance value.
Example
    Creates a straight COGOLine for use in a Traverse. the line is specified us a direction and distance.
    Syntax
    Public Shared Function CreateCOGOStraightLine( _
       ByVal direction As Double, _
       ByVal distance As Double _
    ) As COGOLine
    public static COGOLine CreateCOGOStraightLine(
       double direction,
       double distance
    Parameters
    direction
    distance
    distance value.
    Return Value
    Exceptions
    ExceptionDescription
    direction cannot be NaN.
    distance cannot be NaN or 0.
    Example
    Create a COGOLine defined by direction and distance
    var nAzDirection = ParcelUtilities.Instance.ConvertQuadrantBearingDMSToNorthAzimuthDecDeg("S7-46-51-E");
    var cogoStraightLine = COGOLineBuilder.CreateCOGOStraightLine(nAzDirection, 61.45);
    Create a Traverse
    List<COGOLine> lstCOGOLines = new();
    var direction = ParcelUtilities.Instance.ConvertQuadrantBearingDMSToNorthAzimuthDecDeg("S7-46-51-E");
    lstCOGOLines.Add(COGOLineBuilder.CreateCOGOStraightLine(nAzDirection, 61.45)); //1
    lstCOGOLines.Add(COGOLineBuilder.CreateCOGOStraightLine(166.2625, 37.22));//2
    lstCOGOLines.Add(COGOLineBuilder.CreateCOGOStraightLine(255.2833333, 71.4));//3
    var circArcDef = new CircularArcDefinition
      Radius = -201.0,
      ArcLength = 45.29,
      ChordDirection = ParcelUtilities.Instance.ConvertQuadrantBearingDMSToNorthAzimuthDecDeg("N21-47-57W")
    lstCOGOLines.Add(COGOLineBuilder.CreateCOGOCircularArc(circArcDef));//4
    var tangentCurveDef = new TangentCurveDefinition
      Radius = 169.0,
      ArcLength = 52.40
    lstCOGOLines.Add(COGOLineBuilder.CreateCOGOCircularArc(tangentCurveDef));//5
      Radius = 13.0,
      ArcLength = 22.98
    lstCOGOLines.Add(COGOLineBuilder.CreateCOGOCircularArc(tangentCurveDef));//6
      Radius = -281.0,
      ArcLength = 73.68
    lstCOGOLines.Add(COGOLineBuilder.CreateCOGOCircularArc(tangentCurveDef));//7
    var spatialReference = map?.SpatialReference;
    var travParcel = new Traverse(spatialReference);
    await travParcel.AddCoursesAsync(lstCOGOLines);
    if (travParcel.IsValid())
      ; //insert code to use the traverse
    Requirements
    ArcGIS Pro version: 3.7 or higher.
