Parameters
- angle
- An angle deflection value in decimal degrees.
- fromBacksight
- Is the angle deflection based off a backsight.
- distance
- Distance value.
Return Value
A COGOLine
| Exception | Description |
| System.ArgumentException | angle cannot be NaN. |
| System.ArgumentException | distance cannot be NaN or 0. |
// Clockwise deflection angle 90 degrees, 50.00 var deflectionLine = COGOLineBuilder.CreateCOGOStraightLineByClockwiseDeflectionAngle(90.0, false, 50.00); //Clockwise backsight deflection angle 270 degrees, 50.00' var backSightDeflectionLine = COGOLineBuilder.CreateCOGOStraightLineByClockwiseDeflectionAngle(270.0, true, 50.00);
List<COGOLine> lstCOGOLines = new(); var direction = ParcelUtilities.Instance.ConvertQuadrantBearingDMSToNorthAzimuthDecDeg("S7-46-51-E"); lstCOGOLines.Add(COGOLineBuilder.CreateCOGOStraightLine(nAzDirection, 61.45)); //1 lstCOGOLines.Add(COGOLineBuilder.CreateCOGOStraightLine(166.2625, 37.22));//2 lstCOGOLines.Add(COGOLineBuilder.CreateCOGOStraightLine(255.2833333, 71.4));//3 var circArcDef = new CircularArcDefinition { Radius = -201.0, ArcLength = 45.29, ChordDirection = ParcelUtilities.Instance.ConvertQuadrantBearingDMSToNorthAzimuthDecDeg("N21-47-57W") }; lstCOGOLines.Add(COGOLineBuilder.CreateCOGOCircularArc(circArcDef));//4 var tangentCurveDef = new TangentCurveDefinition { Radius = 169.0, ArcLength = 52.40 }; lstCOGOLines.Add(COGOLineBuilder.CreateCOGOCircularArc(tangentCurveDef));//5 tangentCurveDef = new TangentCurveDefinition { Radius = 13.0, ArcLength = 22.98 }; lstCOGOLines.Add(COGOLineBuilder.CreateCOGOCircularArc(tangentCurveDef));//6 tangentCurveDef = new TangentCurveDefinition { Radius = -281.0, ArcLength = 73.68 }; lstCOGOLines.Add(COGOLineBuilder.CreateCOGOCircularArc(tangentCurveDef));//7 var spatialReference = map?.SpatialReference; var travParcel = new Traverse(spatialReference); await travParcel.AddCoursesAsync(lstCOGOLines); if (travParcel.IsValid()) { ; //insert code to use the traverse }
