ArcGIS.Desktop.Editing.COGO Namespace / Course Class / ExitTangentDirection Property
Example
    Gets the exit tangent direction for the course. Value is in North Azimuth decimal degrees.
    Syntax
    Public ReadOnly Property ExitTangentDirection As Double
    public double ExitTangentDirection {get;}
    Example
    Iterate Traverse Courses
    // iterate thru courses
    foreach (var course in travParcel.Courses)
      var courseCOGOLine = course.COGOLine;
      var entranceTangentDir = course.EntranceTangentDirection;
      var exitTangentDir = course.ExitTangentDirection;
      // tangent to prior course if one of the following
      //     - defined with a ArcGIS.Desktop.Editing.COGO.TangentCurveDefinition
      //     - defined as a straight line defined with a 0 deflection angle.
      var isTangentToPriorCourse = course.IsDefinedAsTangentToPriorCourse;
      // IsTangent if one of the following
      //    - IsTangentToPriorCourse
      //    - is implied tangent - ie difference between entranceTangentDirection and previous courses ExitTangentDirection < tolerance
      var isTangent = course.IsTangent;
    Requirements
    ArcGIS Pro version: 3.7 or higher.
