ArcGIS.Desktop.Editing.COGO Namespace / Course Class / ObjectID Property
Example
    ObjectID Property (Course)
    Gets the ObjectID for the feature created for the course. This is populated only after CreateTraverse has been called for the traverse.
    Syntax
    Public ReadOnly Property ObjectID As Long
    public long ObjectID {get;}
    Property Value
    ObjectID for the course feature. -1 if no feature has been created for the traverse course.
    Example
    Create Features
    var layerName = "Lot_Lines"; //Name of the COGO enabled line layer in the map
    var fLayer = MapView.Active?.Map?.GetLayersAsFlattenedList().OfType<FeatureLayer>().Where(l => l.
              Name.Equals(layerName, StringComparison.OrdinalIgnoreCase)).FirstOrDefault();
    var templateLotLines = fLayer.GetTemplates().FirstOrDefault(); //get the feature template
    var editOper = new EditOperation
      Name = "Create Traverse",
      SelectNewFeatures = false
    var dirOffset = g2gCorrection.GetDirectionOffset();
    var scaleFactor = g2gCorrection.GetConstantScaleFactor();
    var dictAttributes = new Dictionary<string, object>();
    dictAttributes["Rotation"] = dirOffset;
    dictAttributes["Scale"] = scaleFactor;
    if (editOper.CanCreateTraverse(travParcel, templateLotLines))
      await editOper.CreateTraverse(travParcel, templateLotLines, dictAttributes);
    if (!editOper.IsEmpty)
      editOper.Execute();
      // access the mapMember, OID for each created feature
      foreach (var course in travParcel.Courses)
        var mapMember = course.MapMember;
        var oid = course.ObjectID;
        var insp = new ArcGIS.Desktop.Editing.Attributes.Inspector();
        insp.Load(mapMember, oid);
        var shape = insp.Shape;
    Requirements
    ArcGIS Pro version: 3.7 or higher.
