ArcGIS.Desktop.Editing.COGO Namespace / Traverse Class / Export Method
The export options. See TraverseExportOptions.
Example
    Export Method (Traverse)
    Exports the traverse to the ArcMap Traverse file format. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub Export( _
       ByVal options As TraverseExportOptions _
    public void Export(
       TraverseExportOptions options
    Parameters
    options
    Exceptions
    ExceptionDescription
    Options or TraverseExportOptions.OutputFileName is null.
    The traverse file could not be saved.
    Example
    Export a traverse to a file
    var directionDecimalPlaces = 0;
    var distanceDecimalPlaces = 3;
    var exportOptions = new TraverseExportOptions("C:\\MyTraverseFileFolder\\MyTraverseFile.txt",
                                  ArcGIS.Core.CIM.DirectionType.QuadrantBearing,
                                  ArcGIS.Core.CIM.DirectionUnits.DegreesMinutesSeconds,
                                  directionDecimalPlaces, distanceDecimalPlaces);
    travParcel.Export(exportOptions);
    Requirements
    ArcGIS Pro version: 3.7 or higher.
