ArcGIS.Desktop.Editing.COGO Namespace / TraverseManager Class / LoadTraverse Method / LoadTraverse(Traverse,String) Method
The Traverse to load.
The name of the operation added to the undo stack. If not specified, then the "Load traverse" string will be used.
Example
    Loads a traverse into the traverse pane and grid. This adds a single item to the undo stack. Specify the name of the operation using the operationName.
    Syntax
    Public Overloads Function LoadTraverse( _
       ByVal traverse As Traverse, _
       ByVal operationName As String _
    ) As Task
    public Task LoadTraverse(
       Traverse traverse,
       string operationName
    Parameters
    traverse
    operationName
    Exceptions
    ExceptionDescription
    The traverse is null.
    There was an error loading the traverse.
    Example
    Loading a traverse into the Traverse UI
    var isValidTrav = travParcel.IsValid(); //confirm it's a valid traverse
    if (!isValidTrav)
      return;
    //Load the traverse into the traverse grid
    await TraverseManager.Current.LoadTraverse(travParcel, "Load my custom traverse");
    Requirements
    ArcGIS Pro version: 3.7 or higher.
