ArcGIS.Desktop.Editing.COGO Namespace / TraverseManager Class / LoadTraverse Method / LoadTraverse(String,String) Method
The path and name of the ArcMap traverse file..
The name of the operation added to the undo stack. If not specified, then the "Import an ArcMap traverse file" string will be used.
    Loads the specified ArcMap traverse file into the traverse pane and grid. This adds a single item to the undo stack. Specify the name of the operation using the operationName.
    Syntax
    Public Overloads Function LoadTraverse( _
       ByVal traverseFilePath As String, _
       ByVal operationName As String _
    ) As Task
    public Task LoadTraverse(
       string traverseFilePath,
       string operationName
    Parameters
    traverseFilePath
    operationName
    Exceptions
    ExceptionDescription
    The traverseFilePath is null or empty.
    The traverseFilePath does not exist or does not have the correct file extension.
    There was an error loading the traverse file.
    Requirements
    ArcGIS Pro version: 3.7 or higher.
