ArcGIS.Desktop.Mapping Namespace / IDSetCombinationMethod Enumeration
Example Example
    Defines combination methods for setting Link Chart content operations. They determine how the KnowledgeGraphLayerIDSet specified will combine with an existing KnowledgeGraphLayerIDSet. See KnowledgeGraphMappingExtensions.SetLinkChartContent.
    Syntax
    Members
    MemberDescription
    Add Adds to the current ID set.
    New Creates a new ID set.
    Subtract Subtracts from the current ID set.
    Example
    Set only the Selected Features as the Link Chart content
      if (!MapView.Active?.Map?.IsLinkChart == true)
        return;
      await QueuedTask.Run(() =>
        var map = MapView.Active.Map;
        var sel_set = map.GetSelection();
        if (sel_set.Count > 0)
          var kg_layer_id_set = KnowledgeGraphLayerIDSet.FromSelectionSet(sel_set);
          //IDSetCombinationMethod can be New, Add, or Subtract
          if (map.CanSetLinkChartContent(kg_layer_id_set, IDSetCombinationMethod.New))
            map.SetLinkChartContent(kg_layer_id_set, IDSetCombinationMethod.New);
    Append a set of records to a link chart
        return;
      //Assume we have a set of features in an entity type 'Species' and an entity
      //type 'Observation' that we want to append to an existing link chart...
      //Create a dictionary containing the entity uids to be added...
      var dict = new Dictionary<string, List<object>>();
      dict["Species"] = new List<object>();
      dict["Observation"] = new List<object>();
      dict["Species"].Add("{4478D960-A4D6-4930-A151-51A2C6140509}");
      dict["Species"].Add("{97E011A0-C140-4EA9-84E6-19413F6FCEE3}");
      dict["Observation"].Add("{18E1DB21-9F61-4CBE-A488-71AC8B24B605}");
      dict["Observation"].Add("{E378F1B1-FF5E-4EDD-808A-1C395A4857AD}");
        //Get the knowledge graph layer from the link chart
        var kg_layer = MapView.Active?.Map?.GetLayersAsFlattenedList()?
                                  .OfType<ArcGIS.Desktop.Mapping.KnowledgeGraphLayer>()?
                                  .First();
        //arbitrarily get the first feature layer that is a child of the kg layer
        var fl = kg_layer?.GetLayersAsFlattenedList()?
                    .OfType<FeatureLayer>()?.First();
        //Get the kg from the kg layer
        using (var kg = kg_layer.GetDatastore())
          //Create a kg layer id set
          var id_set = KnowledgeGraphIDSet.FromDictionary(kg, dict);
          var kg_layer_id_set = KnowledgeGraphLayerIDSet.FromKnowledgeGraphIDSet(id_set);
          //set the content of the link chart using the id set and the Add combination method
          if (map.CanSetLinkChartContent(kg_layer_id_set, IDSetCombinationMethod.Add))
            map.SetLinkChartContent(kg_layer_id_set, IDSetCombinationMethod.Add);
            //Set the newly added records selected...
            map.SetSelection(SelectionSet.FromKnowledgeGraphLayerIDSet(map, kg_layer_id_set));
    Remove the selected features from the link chart's content
        return;
          if (map.CanSetLinkChartContent(kg_layer_id_set, IDSetCombinationMethod.Subtract))
            map.SetLinkChartContent(kg_layer_id_set, IDSetCombinationMethod.Subtract);
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Desktop.Mapping.IDSetCombinationMethod
    Requirements
    ArcGIS Pro version: 3.7 or higher.
