ArcGIS.Desktop.Mapping Namespace / GridOptions Class
Members Example
    GridOptions Class
    Reference grid options for a map.
    Object Model
    GridOptions ClassCoordinate3D StructureCIMColor ClassCIMColor ClassLinearUnit Class
    Syntax
    Public Class GridOptions
    public class GridOptions
    Remarks
    The reference grid is an overlay comprising configurable horizontal and vertical grid lines for aligning features and visualizing distances as you modify or create features. The reference grid is available on the status bar of the Pro UI at the bottom of the active map or scene. Refer to for more information.
    Example
    Get the Default Grid Options
        QueuedTask.Run(() =>
            var gridOptions = GridOptionsEnvironment.Instance.DefaultGridOptions;
    Get and Set Grid Options for a Map
        //assume
        //var map = MapView.Active.Map;
            //If grid options have not been set for the map, then default grid options are added
            //for the map and returned otherwise the existing gridoptions are returned.
            //NOTE: Grid options are by value meaning a copy is returned. Any changes made to the
            //grid options need to be -set- back on the map using SetGridOptions for the changes to persist.
            var gridOptions = GridOptionsEnvironment.Instance.GetGridOptions(map);
            //change some properties
            gridOptions.RotateWithMap = !gridOptions.RotateWithMap;
            gridOptions.GridLineColor = ColorFactory.Instance.RedRGB;
            gridOptions.GridLineColor = ColorFactory.Instance.BlueRGB;
            //To apply changes, the gridoptions must be set back on the map
            GridOptionsEnvironment.Instance.SetGridOptions(map, gridOptions);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Mapping.GridOptions
    Requirements
    ArcGIS Pro version: 3.7 or higher.
