ArcGIS.Desktop.Mapping Namespace / GridOptionsEnvironment Class / RemoveGridOptions Method
    RemoveGridOptions Method (GridOptionsEnvironment)
    Removes the grid options for the specified map. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void RemoveGridOptions(
       Map map
    Public Sub RemoveGridOptions( _
       ByVal map As Map _
    Parameters
    map
    Exceptions
    ExceptionDescription
    map cannot be null
    Remarks
    If no options exist, this method is a no-op
    Requirements
    ArcGIS Pro version: 3.7 or higher.
