ArcGIS.Desktop.Mapping Namespace / GridOptionsEnvironment Class / Instance Property
Example
    Instance Property (GridOptionsEnvironment)
    Gets the singleton instance for IGridOptionsEnvironment.
    Syntax
    public static IGridOptionsEnvironment Instance {get;}
    Public Shared ReadOnly Property Instance As IGridOptionsEnvironment
    Example
    Show A Grid On the Map - Toggle On/Off
      GridOptionsEnvironment.Instance.ShowGrid = !GridOptionsEnvironment.Instance.ShowGrid;
    Get the Default Grid Options
      await QueuedTask.Run(() =>
        var gridOptions = GridOptionsEnvironment.Instance.DefaultGridOptions;
    Get the Grid Options for a Map
      var gridOptionsMapView = MapView.Active;
      if (gridOptionsMapView == null)
        return;
        //Does the 'map' currently have any options?
        var hasOptions = GridOptionsEnvironment.Instance.HasGridOptions(map);
        //If grid options have not been set for the map, then default grid options are added
        //for the map otherwise the existing gridoptions are returned.
        //NOTE: Grid options are returned by value meaning a copy is always returned. Any changes made to the
        //grid options need to be -set- back on the map using SetGridOptions for the changes to persist.
        var gridOptions = GridOptionsEnvironment.Instance.GetGridOptions(
                                           gridOptionsMapView.Map);
        //Only return grid options if grid options have previously been set:
        var gridOptions2 = GridOptionsEnvironment.Instance.GetGridOptions(
                                           gridOptionsMapView.Map, false);
    Get and Set Grid Options for a Map
      //assume
      //var map = MapView.Active.Map;
        //for the map and returned otherwise the existing gridoptions are returned.
        //NOTE: Grid options are by value meaning a copy is returned. Any changes made to the
        var gridOptions = GridOptionsEnvironment.Instance.GetGridOptions(map);
        //change some properties
        gridOptions.RotateWithMap = !gridOptions.RotateWithMap;
        gridOptions.GridLineColor = ColorFactory.Instance.RedRGB;
        gridOptions.GridLineColor = ColorFactory.Instance.BlueRGB;
        //To apply changes, the gridoptions must be set back on the map
        GridOptionsEnvironment.Instance.SetGridOptions(map, gridOptions);
    Set Grid Origin for Grid Options for a Map
      //assume
      var center_pt = mapView.Extent.Center;
      var width = mapView.Extent.Width;
      var height = mapView.Extent.Height;
      var qtr_width = width * 0.25;
      var qtr_ht = height * 0.25;
        //Set the grid origin
        var x1 = center_pt.X + qtr_width;
        var y1 = center_pt.Y + qtr_ht;
        gridOptions.SetGridOrigin(new Coordinate2D(x1, y1));
        //or use Coordinate3D
        gridOptions.SetGridOrigin(new Coordinate3D(x1, y1, 0));
    Set Various Grid Option parameters for GridOptions for a Map
        //use defaults
        //customize the options as needed
        var gs_rotation = gridOptions.GetGridRotation();
        gridOptions.SetGridRotation(gs_rotation * 1.5);
        var gs_meters = gridOptions.GetGridSpacingMeters();
        var gs_in_spacing_units = gridOptions.GetGridSpacing();
        var gs_units = gridOptions.GridSpacingUnits;
        //meters assumed
        gridOptions.SetGridSpacingInMeters(gs_meters + 10);
        //specify units explicitly
        gridOptions.SetGridSpacing(1000, LinearUnit.Feet);//internally will be converted to meters
        gridOptions.IsGridLines = true;//use lines (default)
        var grid_interval = gridOptions.GridMajorInterval;
        gridOptions.SnapToGridEnabled = true;
        var x1 = center_pt.X - qtr_width;
    Reset the Grid Options for a Map back to Defaults
        if (GridOptionsEnvironment.Instance.HasGridOptions(map))
          //set back to defaults - will overwrite existing
                      GridOptionsEnvironment.Instance.DefaultGridOptions);
    Remove the Grid Options from a Map
          GridOptionsEnvironment.Instance.RemoveGridOptions(map);
    Clear the Grid Options for All Maps
        GridOptionsEnvironment.Instance.ClearGridOptions();
    Requirements
    ArcGIS Pro version: 3.7 or higher.
