ArcGIS.Core.Data.UtilityNetwork.Telecom Namespace / UnitIdentifierManager Class / Combine Method
Elements to combine.
    Combine Method (UnitIdentifierManager)
    Combines the elements. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    telecomElements
    Return Value
    Information about the combined element.
    Exceptions
    ExceptionDescription
    The list of elements is not valid for the combine operation.
    telecomElements is null.
    This operation must be called within an edit operation. For stand-alone CoreHost applications, wrap this call within ArcGIS.Core.Data.Geodatabase.ApplyEdits.
    A geodatabase-related exception has occurred.
    Remarks
    For stand-alone CoreHost applications, calls to this method should be enclosed within a call to ArcGIS.Core.Data.Geodatabase.ApplyEdits.
    Requirements
    ArcGIS Pro version: 3.7 or higher.
