ArcGIS.Core.Data Namespace / ArcGISServerConnectionFile Class / ArcGISServerConnectionFile Constructor
A valid path to the ArcGIS Server connection file that ends with the .ags extension.
The name of the service to connect to.
Example
    Initializes a new instance of the ArcGISServerConnectionFile class.
    Syntax
    public ArcGISServerConnectionFile(
       Uri path,
       string serviceName
    Public Function New( _
       ByVal path As Uri, _
       ByVal serviceName As String _
    Parameters
    path
    serviceName
    Exceptions
    ExceptionDescription
    path and/or serviceName is invalid.
    Example
    Connect to the ArcGISServer using a connection file
      await QueuedTask.Run(() =>
        Uri uriPath = new Uri("path\\to\\the\\ArcGISServerConnectionFile.ags");
        ArcGISServerConnectionFile arcGISServerConnectionFile = new ArcGISServerConnectionFile(uriPath, "FeatureServiceName");
        using (Geodatabase geodatabase = new Geodatabase(arcGISServerConnectionFile))
          // Use the geodatabase.
    Requirements
    ArcGIS Pro version: 3.8 or higher.
