public LasPointElevationRangeFilter GetElevationRangeFilter()
Public Function GetElevationRangeFilter() As LasPointElevationRangeFilter
// get the state of the current elevation range filter
var isEnabled = lasDatasetLayer.IsElevationRangeFilterEnabled;
// turn off the filter
lasDatasetLayer.SetElevationRangeFilterEnabled(false); // or true to turn it on
// get the current elevation range filter and access the values
var elevRangeFilter = lasDatasetLayer.GetElevationRangeFilter();
isEnabled = elevRangeFilter.IsEnabled;
var minZ = elevRangeFilter.MinZ;
var maxZ = elevRangeFilter.MaxZ;
// get minimum and maximum Z values from the LAS Dataset
(minZ, maxZ) = lasDatasetLayer.GetElevationRangeFromDatasetExtent();
// set the elefvation range filter values
// note this doesn't change the enabled state of the elevation range filter
lasDatasetLayer.SetElevationRangeFilter(1.2, 4.5);
// or set the elevation range filter using a LasPointElevationRangeFilter
elevRangeFilter = new LasPointElevationRangeFilter(true, 1.2, 4.5);
lasDatasetLayer.SetElevationRangeFilter(elevRangeFilter);
