ArcGIS.Desktop.Mapping Namespace / LasPointElevationRangeFilter Class
Members Example
    Filter for display of points in a LAS dataset layer. See LasDatasetLayer.GetElevationRangeFilter and LasDatasetLayer.SetElevationRangeFilter.
    Syntax
    public sealed class LasPointElevationRangeFilter
    Public NotInheritable Class LasPointElevationRangeFilter
    Example
    Elevation Range Filter
      // get the state of the current elevation range filter
      var isEnabled = lasDatasetLayer.IsElevationRangeFilterEnabled;
      // turn off the filter
      lasDatasetLayer.SetElevationRangeFilterEnabled(false);  // or true to turn it on
      // get the current elevation range filter and access the values
      var elevRangeFilter = lasDatasetLayer.GetElevationRangeFilter();
      isEnabled = elevRangeFilter.IsEnabled;
      var minZ = elevRangeFilter.MinZ;
      var maxZ = elevRangeFilter.MaxZ;
      // get minimum and maximum Z values from the LAS Dataset
      (minZ, maxZ) = lasDatasetLayer.GetElevationRangeFromDatasetExtent();
      // set the elefvation range filter values
      //  note this doesn't change the enabled state of the elevation range filter
      lasDatasetLayer.SetElevationRangeFilter(1.2, 4.5);
      // or set the elevation range filter using a LasPointElevationRangeFilter
      elevRangeFilter = new LasPointElevationRangeFilter(true, 1.2, 4.5);
      lasDatasetLayer.SetElevationRangeFilter(elevRangeFilter);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Mapping.LasPointElevationRangeFilter
    Requirements
    ArcGIS Pro version: 3.8 or higher.
