ArcGIS.Core.Data Namespace / MobileGeodatabaseConnectionPath Class / Type Property
    Type Property (MobileGeodatabaseConnectionPath)
    The type of mobile geodatabase.
    Syntax
    public MobileGeodatabaseType Type {get;}
    Public ReadOnly Property Type As MobileGeodatabaseType
    Remarks
    If this connector is created using the public constructor, then the type is MobileGeodatabaseType.Unknown. If this connector is created by the system (e.g. Geodatabase.GetConnector), then the type is set to the correct value.
    Requirements
    ArcGIS Pro version: 3.8 or higher.
