ArcGIS.Core.OCR Namespace / OCRManager Class / ExtractFromDocumentAsync Method / ExtractFromDocumentAsync(OCROptions) Method
The OCR options. See OCROptions.
Example
    Extracts information from a document image using the document image, page and output type specified in the ocrOptions. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public Task<OCROutput> ExtractFromDocumentAsync(
       OCROptions ocrOptions
    Public Overloads Function ExtractFromDocumentAsync( _
       ByVal ocrOptions As OCROptions _
    ) As Task(Of OCROutput)
    Parameters
    ocrOptions
    Return Value
    An OCROutput. The instance type depends upon the OCROptions.OutputType used. It can be null if no data can be extracted from the document.
    Exceptions
    ExceptionDescription
    ocrOptions is null.
    The document image could not be found or has an invalid extension for OCR.
    An error occurred within the OCR engine.
    Remarks
    Optical Character Recognition (OCR) technology is used to extract text from the document image. Text extraction and character recognition will be dependent on the quality and content of the image. There might also be difficulty in extracting text from complex data.
    Example
    Extract text from a document using OCROptions
      string docFileName = "c:\\MyData\\MyDocument.tiff";
      var ocrOptions = new OCROptions(docFileName);
      ocrOptions.OutputType = OCROutputType.Text;
      // set a specific page if necessary
      // (if not set, then all pages are scanned)
      // ocrOptions.Page = pageIdx;
      // set the resolution if necessary
      // ocrOptions.Resolution = 400;
      var output = await OCRManager.Instance.ExtractFromDocumentAsync(ocrOptions);
      var textOutput = output as OCRTextOutput;
      var text = textOutput.Text;
    Extract text from a document using a different model
      string docFileName = "c:\\MyData\\MyDocument.jpg";
      // set the language
      // (de.traineddata should be installed at (arcgis_install_folder)\Resources\OCR)
      // if file cannot be found an exception is thrown
      ocrOptions.Model = "de";
      try
      catch (ArcGIS.Core.OCR.Exceptions.OCRException ex)
    Extract TSV output from a document
      string docFileName = "c:\\MyData\\MyDocument.bmp";
      ocrOptions.OutputType = OCROutputType.TSV;
      if (output is OCRTSVOutput ocr_tsvOutput)
        // process the tsv output
        foreach (var page in ocr_tsvOutput.Pages)
          foreach (var block in page.Blocks)
            foreach (var para in block.Paragraphs)
              foreach (var line in para.Lines)
                foreach (var word in line.Words)
                  var content = word.Content;
                  var confidence = word.Confidence;
                  // process content according to confidence
    Requirements
    ArcGIS Pro version: 3.8 or higher.
