string docFileName = "c:\\MyData\\MyDocument.tiff";
var ocrOptions = new OCROptions(docFileName);
ocrOptions.OutputType = OCROutputType.Text;
// set a specific page if necessary
// (if not set, then all pages are scanned)
// ocrOptions.Page = pageIdx;
// set the resolution if necessary
// ocrOptions.Resolution = 400;
var output = await OCRManager.Instance.ExtractFromDocumentAsync(ocrOptions);
var textOutput = output as OCRTextOutput;
var text = textOutput.Text;
string docFileName = "c:\\MyData\\MyDocument.jpg";
// set the language
// (de.traineddata should be installed at (arcgis_install_folder)\Resources\OCR)
// if file cannot be found an exception is thrown
ocrOptions.Model = "de";
try
catch (ArcGIS.Core.OCR.Exceptions.OCRException ex)
string docFileName = "c:\\MyData\\MyDocument.bmp";
ocrOptions.OutputType = OCROutputType.TSV;
if (output is OCRTSVOutput ocr_tsvOutput)
// process the tsv output
foreach (var page in ocr_tsvOutput.Pages)
foreach (var block in page.Blocks)
foreach (var para in block.Paragraphs)
foreach (var line in para.Lines)
foreach (var word in line.Words)
var content = word.Content;
var confidence = word.Confidence;
// process content according to confidence
System.Object
ArcGIS.Core.OCR.OCROptions
