ArcGIS.Core.OCR Namespace / OCRTextOutput Class
Members Example
    OCRTextOutput Class
    Output from an OCR operation requesting text output; that is with OCROptions.OutputType equal to OCROutputType.Text. See OCRManager.ExtractFromDocumentAsync or OCRManager.ExtractFromDocumentAsync.
    Syntax
    public sealed class OCRTextOutput : OCROutput
    Public NotInheritable Class OCRTextOutput
       Inherits OCROutput
    Example
    Extract text from a document using OCROptions
      string docFileName = "c:\\MyData\\MyDocument.tiff";
      var ocrOptions = new OCROptions(docFileName);
      ocrOptions.OutputType = OCROutputType.Text;
      // set a specific page if necessary
      // (if not set, then all pages are scanned)
      // ocrOptions.Page = pageIdx;
      // set the resolution if necessary
      // ocrOptions.Resolution = 400;
      var output = await OCRManager.Instance.ExtractFromDocumentAsync(ocrOptions);
      var textOutput = output as OCRTextOutput;
      var text = textOutput.Text;
    Extract text from a document using a different model
      string docFileName = "c:\\MyData\\MyDocument.jpg";
      // set the language
      // (de.traineddata should be installed at (arcgis_install_folder)\Resources\OCR)
      // if file cannot be found an exception is thrown
      ocrOptions.Model = "de";
      try
      catch (ArcGIS.Core.OCR.Exceptions.OCRException ex)
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.OCR.OCROutput
          ArcGIS.Core.OCR.OCRTextOutput
    Requirements
    ArcGIS Pro version: 3.8 or higher.
