ArcGIS.Core.OCR Namespace / OCRTextOutput Class / Text Property
Example
    Text Property (OCRTextOutput)
    Gets the text detected by the OCR operation.
    Syntax
    public string Text {get;}
    Public ReadOnly Property Text As String
    Example
    Extract text from a document using OCROptions
      string docFileName = "c:\\MyData\\MyDocument.tiff";
      var ocrOptions = new OCROptions(docFileName);
      ocrOptions.OutputType = OCROutputType.Text;
      // set a specific page if necessary
      // (if not set, then all pages are scanned)
      // ocrOptions.Page = pageIdx;
      // set the resolution if necessary
      // ocrOptions.Resolution = 400;
      var output = await OCRManager.Instance.ExtractFromDocumentAsync(ocrOptions);
      var textOutput = output as OCRTextOutput;
      var text = textOutput.Text;
    Extract text from a document using a different model
      string docFileName = "c:\\MyData\\MyDocument.jpg";
      // set the language
      // (de.traineddata should be installed at (arcgis_install_folder)\Resources\OCR)
      // if file cannot be found an exception is thrown
      ocrOptions.Model = "de";
      try
      catch (ArcGIS.Core.OCR.Exceptions.OCRException ex)
    Requirements
    ArcGIS Pro version: 3.8 or higher.
