ArcGIS.Core.OCR Namespace / OCRWord Class / Confidence Property
Example
    Confidence Property
    Gets the confidence that the word recognized by the OCR engine is correct. This is a percentage based score (0 to 100).
    Syntax
    public double Confidence {get;}
    Public ReadOnly Property Confidence As Double
    Example
    Extract TSV output from a document
      string docFileName = "c:\\MyData\\MyDocument.bmp";
      var ocrOptions = new OCROptions(docFileName);
      ocrOptions.OutputType = OCROutputType.TSV;
      // set a specific page if necessary
      // (if not set, then all pages are scanned)
      // ocrOptions.Page = pageIdx;
      // set the resolution if necessary
      // ocrOptions.Resolution = 400;
      var output = await OCRManager.Instance.ExtractFromDocumentAsync(ocrOptions);
      if (output is OCRTSVOutput ocr_tsvOutput)
        // process the tsv output
        foreach (var page in ocr_tsvOutput.Pages)
          foreach (var block in page.Blocks)
            foreach (var para in block.Paragraphs)
              foreach (var line in para.Lines)
                foreach (var word in line.Words)
                  var content = word.Content;
                  var confidence = word.Confidence;
                  // process content according to confidence
    Requirements
    ArcGIS Pro version: 3.8 or higher.
