ArcGIS.Desktop.Editing.COGO Namespace / TraverseFactory Class / ExtractTraverseFromDeedAsync Method
    ExtractTraverseFromDeedAsync Method (TraverseFactory)
    Overload List
    OverloadDescription
    Extracts a set of Traverse objects from a deed image using the ArcGIS.Core.OCR.OCRManager. This method must be called on the MCT. Use QueuedTask.Run.
    Extracts a set of Traverse objects from a specific page of a deed image using the ArcGIS.Core.OCR.OCRManager. This method must be called on the MCT. Use QueuedTask.Run.
    Extracts a set of trTraverse objects from a specific page of a deed image using the ArcGIS.Core.OCR.OCRManager. This method must be called on the MCT. Use QueuedTask.Run.
    Requirements
    ArcGIS Pro version: 3.8 or higher.
