ExtractTraverseFromDeedAsync(String,Int32,SpatialReference,CancellationToken) Method
Extracts a set of tr
Traverse objects from a specific page of a deed image using the
ArcGIS.Core.OCR.OCRManager. This method must be called on the MCT. Use QueuedTask.Run.
Parameters
- deedFileName
- The deed image. pdf, tif, tiff, jpg, jpeg, png and bmp extensions are supported.
- page
- The page you wish to extract information from. The index is 0-based; meaning that you should pass
0 for the first page; 1 for the second page and so on. Use -1 to extract data from all pages in the deed image.
- spatialReference
- The spatial reference to use for the traverse objects.
- cancellationToken
- A System.Threading.CancellationToken used to control cancellation behavior for the returned task.
Return Value
A IReadOnlyList of
Traverse objects. Null cann be returned if no traverse data can be extracted.
ArcGIS Pro version: 3.8 or higher.
