| Overload | Description |
| ExtractTraverseFromDeedAsync(String,SpatialReference) | Extracts a set of Traverse objects from a deed image using the ArcGIS.Core.OCR.OCRManager. This method must be called on the MCT. Use QueuedTask.Run. |
| ExtractTraverseFromDeedAsync(String,SpatialReference,CancellationToken) | Extracts a set of Traverse objects from a deed image using the ArcGIS.Core.OCR.OCRManager. This method must be called on the MCT. Use QueuedTask.Run. |
| ExtractTraverseFromDeedAsync(String,Int32,SpatialReference) | Extracts a set of Traverse objects from a specific page of a deed image using the ArcGIS.Core.OCR.OCRManager. This method must be called on the MCT. Use QueuedTask.Run. |
| ExtractTraverseFromDeedAsync(String,Int32,SpatialReference,CancellationToken) | Extracts a set of Traverse objects from a specific page of a deed image using the ArcGIS.Core.OCR.OCRManager. This method must be called on the MCT. Use QueuedTask.Run. |
