ArcGIS.Desktop.Editing.COGO Namespace / ITraverseFactory Interface / ExtractTraverseFromDeedAsync Method / ExtractTraverseFromDeedAsync(String,SpatialReference,CancellationToken) Method
The deed image. pdf, tif, tiff, jpg, jpeg, png and bmp extensions are supported.
The spatial reference to use for the traverse objects.
A System.Threading.CancellationToken used to control cancellation behavior for the returned task.
    Extracts a set of Traverse objects from a deed image using the ArcGIS.Core.OCR.OCRManager. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    deedFileName
    spatialReference
    cancellationToken
    Return Value
    A IReadOnlyList of Traverse objects. Null cann be returned if no traverse data can be extracted.
    Exceptions
    ExceptionDescription
    deedFileName or spatialReference is null.
    The deed image could not be found or has an invalid extension for OCR.
    The operation was canceled.
    Remarks
    A typical deed contains multiple courses depicting the boundaries of a parcel or the boundaries of more than one parcel. Boundaries start from a well established point-of-beginning and loop back to the same point-of-beginning. Optical Character Recognition (OCR) technology is used to extract text from the deed image and convert it to numerical values for COGO dimensions for the parcel courses.
    Text extraction and character recognition will be dependent on the quality and content of the image. There might also be difficulty in extracting text from complex legal descriptions.
    This method uses the ArcGIS.Core.OCR.OCROutputType.TSV output type to obtain information from the deed. Headers and footers (which often interfere with COGO course extraction) and vertical lines are removed when processing the OCR output.
    Requirements
    ArcGIS Pro version: 3.8 or higher.
