ArcGIS.Desktop.Mapping Namespace / CatalogLayer Class / IsValidDefinitionQuery Method
    IsValidDefinitionQuery Method (CatalogLayer)
    Overload List
    OverloadDescription
    Determines if the specified SQL where clause has valid syntax. That is; the field defined exists on the layer. This method must be called on the MCT. Use QueuedTask.Run.
    Determines if the specified definitionQuery is valid. This method must be called on the MCT. Use QueuedTask.Run.
    Requirements
    ArcGIS Pro version: 3.8 or higher.
