ArcGIS.Desktop.Mapping Namespace / CatalogLayer Class
Members Example
    CatalogLayer Class
    Represents a layer with a reference to a catalog dataset which contains references to multiple datasets, packages, and/or portal items. The catalog dataset items do not have to be related.
    Object Model
    CatalogLayer ClassDefinitionQuery ClassLayer ClassCatalogDataset ClassCIMDataConnection ClassTimeExtent ClassCIMBaseLayer ClassElevationTypeDefinition ClassSpatialReference ClassTimeParameters ClassSurfaceZsResult ClassMap ClassILayerContainer InterfaceEnvelope ClassDefinitionQuery Class
    Syntax
    Remarks
    To create a catalog layer use CatalogLayerCreationParams with LayerFactory.
    The item references, within the catalog dataset, can be visualized, filtered, and queried dynamically in maps and scenes.
    Example
    Create Catalog Layer using Uri to a Catalog Feature Class
      var createParams = new CatalogLayerCreationParams(new Uri(@"C:\CatalogLayer\CatalogDS.gdb\HurricaneCatalogDS"));
      //Set the definition query
      createParams.DefinitionQuery = new DefinitionQuery("Query1", "cd_itemname = 'PuertoRico'");
      //Set name of the new Catalog Layer
      createParams.Name = "PuertoRico";
      //Create Layer
      var catalogLayer = await QueuedTask.Run(() =>
        LayerFactory.Instance.CreateLayer<CatalogLayer>(createParams, map));
    Create Catalog Layer using CatalogDataset
      //Get the CatalogDataset of another Catalog layer
      var existingCatalogLayer = map.GetLayersAsFlattenedList().OfType<CatalogLayer>().FirstOrDefault();
      if (existingCatalogLayer != null)
          var catalogDataset = existingCatalogLayer.GetCatalogDataset();
          //Configure the settings for a new Catalog layer using the CatalogDataset of an existing layer
          var catalogLyrParams = new CatalogLayerCreationParams(catalogDataset);
          catalogLyrParams.Name = "NewCatalogLayerFromAnotherCatalogLayer";
          catalogLyrParams.DefinitionQuery = new DefinitionQuery("Query1", "cd_itemname = 'Asia'");
          LayerFactory.Instance.CreateLayer<CatalogLayer>(catalogLyrParams, map);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase
          ArcGIS.Desktop.Mapping.MapMember
             ArcGIS.Desktop.Mapping.Layer
                ArcGIS.Desktop.Mapping.CompositeLayer
                   ArcGIS.Desktop.Mapping.CatalogLayer
    Requirements
    ArcGIS Pro version: 3.1 or higher.
