public Task<bool> IsValidDefinitionQuery( string sql )
Public Overloads Function IsValidDefinitionQuery( _ ByVal sql As String _ ) As Task(Of Boolean)
Parameters
- sql
- The SQL clause to check.
Return Value
True if valid.
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
