ArcGIS.Desktop.Mapping Namespace / SubtypeGroupLayer Class / IsValidDefinitionQuery Method / IsValidDefinitionQuery(String) Method
The SQL clause to check.
    Determines if the specified SQL where clause has valid syntax. That is; the field defined exists on the layer. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public Task<bool> IsValidDefinitionQuery(
       string sql
    Public Overloads Function IsValidDefinitionQuery( _
       ByVal sql As String _
    ) As Task(Of Boolean)
    Parameters
    sql
    Return Value
    True if valid.
    Exceptions
    ExceptionDescription
    Remarks
    This method does not check whether records will be returned from the SQL query; just whether the query has valid syntax for the layer.
    Requirements
    ArcGIS Pro version: 3.8 or higher.
