ArcGIS.Desktop.Mapping Namespace / SubtypeGroupLayer Class / IsValidDefinitionQuery Method / IsValidDefinitionQuery(DefinitionQuery) Method
The definition query to check.
    Determines if the specified definitionQuery is valid. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public Task<bool> IsValidDefinitionQuery(
       DefinitionQuery definitionQuery
    Public Overloads Function IsValidDefinitionQuery( _
       ByVal definitionQuery As DefinitionQuery _
    ) As Task(Of Boolean)
    Parameters
    definitionQuery
    Return Value
    True if valid.
    Exceptions
    ExceptionDescription
    Remarks
    This method does not check whether records will be returned from the definitionQuery; just whether the query where clause has valid syntax for the layer and the spatial filter (if defined) is valid.
    Requirements
    ArcGIS Pro version: 3.8 or higher.
