ArcGIS.Core.Data.UtilityNetwork Namespace / SubnetworkUpdateOptions Class / ForceUpdate Property
    ForceUpdate Property (SubnetworkUpdateOptions)
    Specifies whether the subnetwork update operation can run against subnetworks that are not marked as dirty. The default is false which means the subnetwork update operation will return an error if the subnetwork is not marked as dirty.
    Syntax
    public bool ForceUpdate {get; set;}
    Public Property ForceUpdate As Boolean
    Requirements
    ArcGIS Pro version: 3.8 or higher.
