ArcGIS.Core.Data.DDL Namespace / CodedValueDomainDescription Class / CodedValueDomainDescription Constructor / CodedValueDomainDescription Constructor(CodedValueDomain)
The ArcGIS.Core.Data.CodedValueDomain that the description object is representing.
Example
    Creates a description object of the ArcGIS.Core.Data.CodedValueDomain.
    Syntax
    Public Function New( _
       ByVal codedValueDomain As CodedValueDomain _
    public CodedValueDomainDescription(
       CodedValueDomain codedValueDomain
    Parameters
    codedValueDomain
    Exceptions
    ExceptionDescription
    codedValueDomain is null.
    Example
    Delete Domain on KG Schemas with SchemaBuilder
      await QueuedTask.Run(() =>
        using (var kg = GetKnowledgeGraph(url))
          //Get all the domains in the KG
          var domains = kg.GetDomains();
          var sb = new SchemaBuilder(kg);
          foreach (var domain in domains)
            //skip the special provenance domain
            var name = domain.GetName();
            if (string.Compare(name, "esri__provenanceSourceType", true) == 0)
              continue;//skip this one
            //Delete all other domains
            if (domain is ArcGIS.Core.Data.RangeDomain rd)
              sb.Delete(new RangeDomainDescription(rd));
            else if (domain is ArcGIS.Core.Data.CodedValueDomain cvd)
              sb.Delete(new CodedValueDomainDescription(cvd));
          try
            //note: will throw an InvalidOperationException if there are no operations
            //to run. Will also delete associated fields dependent on deleted domain(s)
            if (!kg.ApplySchemaEdits(sb))
              var err_msg = string.Join(",", sb.ErrorMessages.ToArray());
              System.Diagnostics.Debug.WriteLine($"Delete domains error: {err_msg}");
          catch (Exception ex)
            System.Diagnostics.Debug.WriteLine(ex.ToString());
    KnowledgeGraph GetKnowledgeGraph(string url)
      var kg_props =
        new KnowledgeGraphConnectionProperties(new Uri(url));
      return new KnowledgeGraph(kg_props);
    Requirements
