Public Function New( _ ByVal tableDefinition As TableDefinition _ )
public TableDescription( TableDefinition tableDefinition )
Parameters
- tableDefinition
- The ArcGIS.Core.Data.Table that the description object is representing.
| Exception | Description |
| System.ArgumentNullException | tableDefinition is null. |
// Must be called within QueuedTask.Run
void CreateTableSnippet(Geodatabase geodatabase, CodedValueDomain inspectionResultsDomain)
// Create a PoleInspection table with the following fields
// GlobalID
// ObjectID
// InspectionDate (date)
// InspectionResults (pre-existing InspectionResults coded value domain)
// InspectionNotes (string)
// This helper routine creates a FieldDescription for a GlobalID field with default values
FieldDescription globalIDFieldDescription = FieldDescription.CreateGlobalIDField();
// This helper routine creates a FieldDescription for an ObjectID field with default values
FieldDescription objectIDFieldDescription = FieldDescription.CreateObjectIDField();
// Create a FieldDescription for the InspectionDate field
FieldDescription inspectionDateFieldDescription = new FieldDescription("InspectionDate", FieldType.Date)
AliasName = "Inspection Date"
// This helper routine creates a FieldDescription for a Domain field (from a pre-existing domain)
FieldDescription inspectionResultsFieldDescription = FieldDescription.CreateDomainField("InspectionResults",
new CodedValueDomainDescription(inspectionResultsDomain));
inspectionResultsFieldDescription.AliasName = "Inspection Results";
// This helper routine creates a FieldDescription for a string field
FieldDescription inspectionNotesFieldDescription =
FieldDescription.CreateStringField("InspectionNotes", 512);
inspectionNotesFieldDescription.AliasName = "Inspection Notes";
// Assemble a list of all of our field descriptions
List<FieldDescription> fieldDescriptions = new List<FieldDescription>()
globalIDFieldDescription, objectIDFieldDescription, inspectionDateFieldDescription,
inspectionResultsFieldDescription, inspectionNotesFieldDescription
// Create a TableDescription object to describe the table to create
TableDescription tableDescription = new TableDescription("PoleInspection", fieldDescriptions);
// Create a SchemaBuilder object
SchemaBuilder schemaBuilder = new SchemaBuilder(geodatabase);
// Add the creation of PoleInspection to our list of DDL tasks
schemaBuilder.Create(tableDescription);
// Execute the DDL
bool success = schemaBuilder.Build();
// Inspect error messages
if (!success)
IReadOnlyList<string> errorMessages = schemaBuilder.ErrorMessages;
//etc.
