Public Property PolygonPlacementMethod As StandardPolygonPlacementMethod
public StandardPolygonPlacementMethod PolygonPlacementMethod {get; set;}
// Note: call within QueuedTask.Run()
//Get the layer's definition
var lyrDefn = featureLayer.GetDefinition() as CIMFeatureLayer;
//Get the label classes - we need the first one
var listLabelClasses = lyrDefn.LabelClasses.ToList();
var theLabelClass = listLabelClasses.FirstOrDefault();
//Modify label Placement
//Check if the label engine is Maplex or standard.
CIMGeneralPlacementProperties labelEngine = MapView.Active.Map.GetDefinition().GeneralPlacementProperties;
if (labelEngine is CIMStandardGeneralPlacementProperties)
//Current labeling engine is Standard Labeling engine
theLabelClass.StandardLabelPlacementProperties.PolygonPlacementMethod =
StandardPolygonPlacementMethod.AlwaysHorizontal;
theLabelClass.StandardLabelPlacementProperties.PlaceOnlyInsidePolygon = true;
else
//Current labeling engine is Maplex labeling engine
theLabelClass.MaplexLabelPlacementProperties.PolygonFeatureType =
MaplexPolygonFeatureType.LandParcel;
theLabelClass.MaplexLabelPlacementProperties.AvoidPolygonHoles = true;
theLabelClass.MaplexLabelPlacementProperties.PolygonPlacementMethod =
MaplexPolygonPlacementMethod.HorizontalInPolygon;
theLabelClass.MaplexLabelPlacementProperties.CanPlaceLabelOutsidePolygon = true;
lyrDefn.LabelClasses = listLabelClasses.ToArray(); //Set the labelClasses back
featureLayer.SetDefinition(lyrDefn); //set the layer's definition
//set the label's visiblity
featureLayer.SetLabelVisibility(true);
