//Note: Must be on QueuedTask.Run(() => { ...
//Build geometry
Coordinate2D coord2D = new Coordinate2D(2.0, 10.0);
//Reference a point symbol in a style
StyleProjectItem stylePrjItm = Project.Current.GetItems<StyleProjectItem>()
.FirstOrDefault(item => item.Name == "ArcGIS 2D");
SymbolStyleItem symStyleItm = stylePrjItm.SearchSymbols(
StyleItemType.PointSymbol, "City Hall")[0];
CIMPointSymbol pointSym = symStyleItm.Symbol as CIMPointSymbol;
pointSym.SetSize(50);
var elemInfo = new ElementInfo()
CustomProperties = new List<CIMStringMap>() {
new CIMStringMap() { Key = "Key1", Value = "Value1"},
new CIMStringMap() { Key = "Key2", Value = "Value2"}
Anchor = Anchor.TopRightCorner,
Rotation = 45.0
var graphic = GraphicFactory.Instance.CreateSimpleGraphic(
coord2D.ToMapPoint(), pointSym);
ElementFactory.Instance.CreateGraphicElement(
layout, graphic, "New Point", true, elemInfo);
//Build geometry
Coordinate2D ll = new Coordinate2D(1, 1);
Coordinate2D ur = new Coordinate2D(4, 4);
Envelope env = EnvelopeBuilderEx.CreateEnvelope(ll, ur);
var tableFrameInfo = new TableFrameInfo()
MapFrameName = "Map Frame",
MapMemberUri = "CIMPATH=USNationalParks/NationalParks.json"
var attribs = new List<CIMStringMap>();
for (int i = 1; i < 6; i++)
attribs.Add(new CIMStringMap
Key = $"Key {i}",
Value = $"Value {i}"
CustomProperties = attribs
var tableFrameElem = ElementFactory.Instance.CreateMapSurroundElement(
layout, env.Center, tableFrameInfo,
"New Table Frame", false, elemInfo) as TableFrame;
