ArcGIS.Core.CIM Namespace / CIMStringMap Class / Value Property
Example
    Value Property (CIMStringMap)
    Gets or sets the value.
    Syntax
    Public Property Value As String
    public string Value {get; set;}
    Example
    Create Point Element
      //Note: Must be on QueuedTask.Run(() => { ...
      //Build geometry
      Coordinate2D coord2D = new Coordinate2D(2.0, 10.0);
      //Reference a point symbol in a style
      StyleProjectItem stylePrjItm = Project.Current.GetItems<StyleProjectItem>()
                .FirstOrDefault(item => item.Name == "ArcGIS 2D");
      SymbolStyleItem symStyleItm = stylePrjItm.SearchSymbols(
                            StyleItemType.PointSymbol, "City Hall")[0];
      CIMPointSymbol pointSym = symStyleItm.Symbol as CIMPointSymbol;
      pointSym.SetSize(50);
      var elemInfo = new ElementInfo()
        CustomProperties = new List<CIMStringMap>() {
        new CIMStringMap() { Key = "Key1", Value = "Value1"},
        new CIMStringMap() { Key = "Key2", Value = "Value2"}
        Anchor = Anchor.TopRightCorner,
        Rotation = 45.0
      var graphic = GraphicFactory.Instance.CreateSimpleGraphic(
                                    coord2D.ToMapPoint(), pointSym);
      ElementFactory.Instance.CreateGraphicElement(
        layout, graphic, "New Point", true, elemInfo);
    Create Table Frame 2
      //Build geometry
      Coordinate2D ll = new Coordinate2D(1, 1);
      Coordinate2D ur = new Coordinate2D(4, 4);
      Envelope env = EnvelopeBuilderEx.CreateEnvelope(ll, ur);
      var tableFrameInfo = new TableFrameInfo()
        MapFrameName = "Map Frame",
        MapMemberUri = "CIMPATH=USNationalParks/NationalParks.json"
      var attribs = new List<CIMStringMap>();
      for (int i = 1; i < 6; i++)
        attribs.Add(new CIMStringMap
          Key = $"Key {i}",
          Value = $"Value {i}"
        CustomProperties = attribs
      var tableFrameElem = ElementFactory.Instance.CreateMapSurroundElement(
                                    layout, env.Center, tableFrameInfo,
                                    "New Table Frame", false, elemInfo) as TableFrame;
    Requirements
