ArcGIS.Core.CIM Namespace / CIMTableView Class / SelectionMode Property
Example
    Gets or sets a value indicating whether to view the table in selection mode.
    Syntax
    public bool SelectionMode {get; set;}
    Public Property SelectionMode As Boolean
    Example
    Display Table pane for Map Member
      mapMember = MapView.Active.Map.GetLayersAsFlattenedList().OfType<MapMember>().FirstOrDefault();
      //Gets or creates the CIMMapTableView for a MapMember.
      var mapTableView = FrameworkApplication.Panes.GetMapTableView(mapMember);
      //Configure the table view
      mapTableView.DisplaySubtypeDomainDescriptions = false;
      mapTableView.SelectionMode = false;
      mapTableView.ShowOnlyContingentValueFields = true;
      mapTableView.HighlightInvalidContingentValueFields = true;
      //Open the table pane using the configured tableView. If a table pane is already open it will be activated.
      //You must be on the UI thread to call this function.
      var tablePane = FrameworkApplication.Panes.OpenTablePane(mapTableView);
    Requirements
