ArcGIS.Core.CIM Namespace / CIMTextGraphicBase Class / Shape Property
Example
    Shape Property (CIMTextGraphicBase)
    Gets or sets the geometry of the text graphic.
    Syntax
    public Geometry Shape {get; set;}
    Public Property Shape As Geometry
    Example
    Rotate or Move the Annotation
      var oid = 1; //ObjectID of the annotation feature to modify
      await QueuedTask.Run(() =>
        //Don't use 'Shape'....Shape is the bounding box of the annotation text. This is NOT what you want...
        //var insp = new Inspector();
        //insp.Load(annotationLayer, oid);
        //var shape = insp["SHAPE"] as Polygon;
        //...wrong shape...
        //Instead, we must get the TextGraphic from the anno feature.
        //The TextGraphic shape will be the anno baseline...
        QueryFilter qf = new QueryFilter()
          WhereClause = "OBJECTID = 1"
        //annotationLayer is ~your~ Annotation layer
        using var rowCursor = annotationLayer.Search(qf);
        if (rowCursor.MoveNext())
          using (var annoFeature = rowCursor.Current as
          ArcGIS.Core.Data.Mapping.AnnotationFeature)
            var graphic = annoFeature.GetGraphic();
            var textGraphic = graphic as CIMTextGraphic;
            var textLine = textGraphic.Shape as Polyline;
            // rotate the shape 90 degrees
            var origin = GeometryEngine.Instance.Centroid(textLine);
            Geometry rotatedPolyline = GeometryEngine.Instance.Rotate(textLine, origin, System.Math.PI / 2);
            //Move the line 5 "units" in the x and y direction
            //GeometryEngine.Instance.Move(textLine, 5, 5);
            EditOperation op = new EditOperation();
            op.Name = "Change annotation angle";
            op.Modify(annotationLayer, oid, rotatedPolyline);
            op.Execute();
    Requirements
