public PatchShape Patch {get; set;}
Public Property Patch As PatchShape
await QueuedTask.Run(() =>
//The goal is to construct the CIMUniqueValueRenderer which will be applied to the feature layer.
// To do this, the following are the objects we need to set the renderer up with the fields and symbols.
// As a reference, this is the USCities dataset. Snippet will create a unique value renderer that applies
// specific symbols to all the cities in California and Alabama. The rest of the cities will use a default symbol.
// First create a "CIMUniqueValueClass" for the cities in Alabama.
List<CIMUniqueValue> listUniqueValuesAlabama = new List<CIMUniqueValue> { new CIMUniqueValue { FieldValues = new string[] { "Alabama" } } };
CIMUniqueValueClass alabamaUniqueValueClass = new CIMUniqueValueClass
Editable = true,
Label = "Alabama",
Patch = PatchShape.Default,
Symbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.RedRGB).MakeSymbolReference(),
Visible = true,
Values = listUniqueValuesAlabama.ToArray()
// Create a "CIMUniqueValueClass" for the cities in California.
List<CIMUniqueValue> listUniqueValuescalifornia = new List<CIMUniqueValue> { new CIMUniqueValue { FieldValues = new string[] { "California" } } };
CIMUniqueValueClass californiaUniqueValueClass = new CIMUniqueValueClass
Editable = true,
Label = "California",
Symbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.BlueRGB).MakeSymbolReference(),
Visible = true,
Values = listUniqueValuescalifornia.ToArray()
//Create a list of the above two CIMUniqueValueClasses
List<CIMUniqueValueClass> listUniqueValueClasses = new List<CIMUniqueValueClass>
alabamaUniqueValueClass, californiaUniqueValueClass
//Create a list of CIMUniqueValueGroup
CIMUniqueValueGroup uvg = new CIMUniqueValueGroup
Classes = listUniqueValueClasses.ToArray(),
List<CIMUniqueValueGroup> listUniqueValueGroups = new List<CIMUniqueValueGroup> { uvg };
//Create the CIMUniqueValueRenderer
CIMUniqueValueRenderer uvr = new CIMUniqueValueRenderer
UseDefaultSymbol = true,
DefaultLabel = "all other values",
DefaultSymbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.GreyRGB).MakeSymbolReference(),
Groups = listUniqueValueGroups.ToArray(),
Fields = new string[] { "STATE_NAME" }
//Set the feature layer's renderer.
featureLayer.SetRenderer(uvr);
