ArcGIS.Core.CIM Namespace / CIMUniqueValueClass Class / Values Property
Example
    Values Property (CIMUniqueValueClass)
    Gets or sets the values this class corresponds to.
    Syntax
    public CIMUniqueValue[] Values {get; set;}
    Public Property Values As CIMUniqueValue()
    Example
    Create a UniqueValueRenderer to specify symbols to values
      await QueuedTask.Run(() =>
      //The goal is to construct the CIMUniqueValueRenderer which will be applied to the feature layer.
      // To do this, the following are the objects we need to set the renderer up with the fields and symbols.
      // As a reference, this is the USCities dataset. Snippet will create a unique value renderer that applies
      // specific symbols to all the cities in California and Alabama.  The rest of the cities will use a default symbol.
      // First create a "CIMUniqueValueClass" for the cities in Alabama.
      List<CIMUniqueValue> listUniqueValuesAlabama = new List<CIMUniqueValue> { new CIMUniqueValue { FieldValues = new string[] { "Alabama" } } };
      CIMUniqueValueClass alabamaUniqueValueClass = new CIMUniqueValueClass
        Editable = true,
        Label = "Alabama",
        Patch = PatchShape.Default,
        Symbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.RedRGB).MakeSymbolReference(),
        Visible = true,
        Values = listUniqueValuesAlabama.ToArray()
      // Create a "CIMUniqueValueClass" for the cities in California.
      List<CIMUniqueValue> listUniqueValuescalifornia = new List<CIMUniqueValue> { new CIMUniqueValue { FieldValues = new string[] { "California" } } };
      CIMUniqueValueClass californiaUniqueValueClass = new CIMUniqueValueClass
        Editable = true,
        Label = "California",
        Symbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.BlueRGB).MakeSymbolReference(),
        Visible = true,
        Values = listUniqueValuescalifornia.ToArray()
      //Create a list of the above two CIMUniqueValueClasses
      List<CIMUniqueValueClass> listUniqueValueClasses = new List<CIMUniqueValueClass>
                    alabamaUniqueValueClass, californiaUniqueValueClass
      //Create a list of CIMUniqueValueGroup
      CIMUniqueValueGroup uvg = new CIMUniqueValueGroup
        Classes = listUniqueValueClasses.ToArray(),
      List<CIMUniqueValueGroup> listUniqueValueGroups = new List<CIMUniqueValueGroup> { uvg };
      //Create the CIMUniqueValueRenderer
      CIMUniqueValueRenderer uvr = new CIMUniqueValueRenderer
        UseDefaultSymbol = true,
        DefaultLabel = "all other values",
        DefaultSymbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.GreyRGB).MakeSymbolReference(),
        Groups = listUniqueValueGroups.ToArray(),
        Fields = new string[] { "STATE_NAME" }
      //Set the feature layer's renderer.
      featureLayer.SetRenderer(uvr);
    Setting a unique value renderer for latest observations
        var url = @"https://geoeventsample1.esri.com:6443/arcgis/rest/services/AirportTraffics/StreamServer";
        var uri = new Uri(url, UriKind.Absolute);
        var createParams = new FeatureLayerCreationParams(uri)
          IsVisible = false
        streamLayer = LayerFactory.Instance.CreateLayer<StreamLayer>(
                            createParams, map);
        //Define the unique values by hand
        var uvr = new CIMUniqueValueRenderer()
          Fields = new string[] { "ACTYPE" },
          DefaultLabel = "Others",
                      CIMColor.CreateRGBColor(185, 185, 185), 8, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
        var classes = new List<CIMUniqueValueClass>
          //add in classes - one for ACTYPE of 727, one for DC 9
          new CIMUniqueValueClass()
            Values = new CIMUniqueValue[] {
                    new CIMUniqueValue() { FieldValues = new string[] { "B727" } } },
            Visible = true,
            Label = "Boeing 727",
                      ColorFactory.Instance.RedRGB, 10, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
                    new CIMUniqueValue() { FieldValues = new string[] { "DC9" } } },
            Visible = true,
            Label = "DC 9",
                      ColorFactory.Instance.GreenRGB, 10, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
        //add the classes to a group
        var groups = new List<CIMUniqueValueGroup>()
        new CIMUniqueValueGroup() {
           Classes = classes.ToArray()
        //add the groups to the renderer
        uvr.Groups = groups.ToArray();
        //Apply the renderer (for current observations)
        streamLayer.SetRenderer(uvr);
        streamLayer.SetVisibility(true);//turn on the layer
    Setting a unique value renderer for latest observations 2
        //Define the classes by hand to avoid using CreateRenderer(...)
        CIMUniqueValueClass uvcB727 = new CIMUniqueValueClass()
          Values = new CIMUniqueValue[] { new CIMUniqueValue() { FieldValues = new string[] { "B727" } } },
          Visible = true,
          Symbol = SymbolFactory.Instance.ConstructPointSymbol(CIMColor.CreateRGBColor(255, 0, 0), 8, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
        CIMUniqueValueClass uvcD9 = new CIMUniqueValueClass()
          Values = new CIMUniqueValue[] { new CIMUniqueValue() { FieldValues = new string[] { "DC9" } } },
          Visible = true,
          Label = "DC 9",
          Symbol = SymbolFactory.Instance.ConstructPointSymbol(CIMColor.CreateRGBColor(0, 255, 0), 8, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
        //Assign the classes to a group
        CIMUniqueValueGroup uvGrp = new CIMUniqueValueGroup()
          Classes = new CIMUniqueValueClass[] { uvcB727, uvcD9 }
        //assign the group to the renderer
        var UVrndr = new CIMUniqueValueRenderer()
          Groups = new CIMUniqueValueGroup[] { uvGrp },
        //set the renderer. Depending on the current events received, the
        //layer may or may not have events for each of the specified
        //unique value classes
        streamLayer.SetRenderer(UVrndr);
    Requirements
