ArcGIS.Core.Data Namespace / Attachment Class / GetAttachmentID Method
Example
    Gets the object ID of the attachment. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public long GetAttachmentID()
    Public Function GetAttachmentID() As Long
    Return Value
    The object ID of the attachment.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Example
    Deleting Attachments
      await QueuedTask.Run(() =>
        using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file\\sdefile.sde"))))
        using (Table inspectionTable = geodatabase.OpenDataset<Table>("luCodeInspection"))
          QueryFilter queryFilter = new QueryFilter { WhereClause = "ACTION = '1st Notice'" };
          using (RowCursor cursor = inspectionTable.Search(queryFilter, false))
            while (cursor.MoveNext())
              using (Row currentRow = cursor.Current)
                IReadOnlyList<Attachment> rowAttachments = currentRow.GetAttachments(null, true);
                IEnumerable<Attachment> attachments = rowAttachments.Where(attachment =>
                  attachment.GetContentType().Equals("application/pdf"));
                IReadOnlyList<long> attachmentIDs =
                  attachments.Select(attachment => attachment.GetAttachmentID()) as IReadOnlyList<long>;
                IReadOnlyDictionary<long, Exception> failures = currentRow.DeleteAttachments(attachmentIDs);
                if (failures.Count > 0)
                  //process errors
    Requirements
