ArcGIS.Core.Data Namespace / Attachment Class / GetGlobalID Method
    GetGlobalID Method (Attachment)
    Gets the global ID of the attachment if supported. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public Guid GetGlobalID()
    Public Function GetGlobalID() As Guid
    Return Value
    A valid System.Guid if the attachment has a global ID; otherwise, System.Guid.Empty.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Requirements
