ArcGIS.Core.Data Namespace / Attachment Class / GetName Method
Example
    GetName Method (Attachment)
    Gets the file name of the attached document. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public string GetName()
    Public Function GetName() As String
    Return Value
    The name of the attached document.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Example
    Updating Attachments
      await QueuedTask.Run(() =>
        using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file\\sdefile.sde"))))
        using (FeatureClass landUseCaseFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.LandUseCase"))
          QueryFilter filter = new QueryFilter { WhereClause = "CASETYPE = 'Rezoning'" };
          using (RowCursor landUseCursor = landUseCaseFeatureClass.Search(filter, false))
            while (landUseCursor.MoveNext())
              using (Feature rezoningUseCase = (Feature)landUseCursor.Current)
                IReadOnlyList<Attachment> rezoningAttachments = rezoningUseCase.GetAttachments();
                IEnumerable<Attachment> filteredAttachments = rezoningAttachments.Where(attachment => !attachment.GetName().Contains("rezoning"));
                foreach (Attachment attachmentToUpdate in filteredAttachments)
                  attachmentToUpdate.SetName(attachmentToUpdate.GetName().Replace(".pdf", "Rezoning.pdf"));
                  rezoningUseCase.UpdateAttachment(attachmentToUpdate);
    Requirements
