ArcGIS.Core.Data Namespace / Attachment Class / GetParentGlobalID Method
    Gets the global ID of the parent row. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public Guid GetParentGlobalID()
    Public Function GetParentGlobalID() As Guid
    Return Value
    A valid System.Guid if the attachment's parent row has a global ID; otherwise, System.Guid.Empty.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Requirements
