ArcGIS.Core.Data Namespace / Attachment Class / GetSize Method
    GetSize Method (Attachment)
    Gets the size of the attached document in bytes and is calculated when the data is assigned. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public int GetSize()
    Public Function GetSize() As Integer
    Return Value
    The size of the attached document in bytes.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Requirements
