ArcGIS.Core.Data Namespace / Attachment Class / SetName Method
The name of the attached document.
Example
    SetName Method (Attachment)
    Sets the file name of the attached document. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void SetName(
       string attachmentName
    Public Sub SetName( _
       ByVal attachmentName As String _
    Parameters
    attachmentName
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Example
    Updating Attachments
      await QueuedTask.Run(() =>
        using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file\\sdefile.sde"))))
        using (FeatureClass landUseCaseFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.LandUseCase"))
          QueryFilter filter = new QueryFilter { WhereClause = "CASETYPE = 'Rezoning'" };
          using (RowCursor landUseCursor = landUseCaseFeatureClass.Search(filter, false))
            while (landUseCursor.MoveNext())
              using (Feature rezoningUseCase = (Feature)landUseCursor.Current)
                IReadOnlyList<Attachment> rezoningAttachments = rezoningUseCase.GetAttachments();
                IEnumerable<Attachment> filteredAttachments = rezoningAttachments.Where(attachment => !attachment.GetName().Contains("rezoning"));
                foreach (Attachment attachmentToUpdate in filteredAttachments)
                  attachmentToUpdate.SetName(attachmentToUpdate.GetName().Replace(".pdf", "Rezoning.pdf"));
                  rezoningUseCase.UpdateAttachment(attachmentToUpdate);
    Requirements
