ArcGIS.Core.Data Namespace / AttributedRelationship Class / Item Property / Item(Int32) Property
The index of the field.
    Gets and sets the value of a field given its index position. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public object Item(
       int index
    ) {get; set;}
    Public Overloads Property Item( _
       ByVal index As Integer _
    ) As Object
    Parameters
    index
    Property Value
    The value of the field.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Remarks
    The index for the fields is zero based.
    Requirements
