ArcGIS.Core.Data Namespace / AttributedRelationship Class / Item Property
    Item Property (AttributedRelationship)
    Gets and sets the value of a field given its index position. This method must be called on the MCT. Use QueuedTask.Run.
    Overload List
    OverloadDescription
    Gets and sets the value of a field given its attribute name or alias name. This method must be called on the MCT. Use QueuedTask.Run.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Remarks
    The index for the fields is zero based.
    Requirements
