ArcGIS.Core.Data Namespace / AttributedRelationship Class / Item Property / Item(String) Property
The attribute name or alias name of the field.
    Gets and sets the value of a field given its attribute name or alias name. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public object Item(
       string fieldName
    ) {get; set;}
    Public Overloads Property Item( _
       ByVal fieldName As String _
    ) As Object
    Parameters
    fieldName
    Property Value
    The value of the field.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred. For example, fieldName is invalid or does not exist.
    The index of fieldName corresponds to a shape field index and the type of shape (i.e., geometry) is not supported.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Remarks
    fieldName can be either an attribute name or alias name. If fieldName does not exist as an attribute name, it will be treated as an alias name. If the alias name still does not exist, an exception will be thrown.
    Requirements
